high cost of tire replacement--getting harder to get on-farm
Posted by zooeyhall on October 03, 2009 at 19:45:21 from (74.46.144.125):
Had to get one of the rear tires on my M replaced last week. I had to replace the other one this spring. I farm 160 acres and the tires were about 10 years old and just wore out from the field work.
Replacing a 13.6 x 38 6 ply with tube and fluid cost $575! OUCH!!
It also seems to be getting harder to find someone that replaces these tires on-the-farm. There used to be more service stations around here that did this. When I called them up they say they no longer have a truck and have gotten out of the farm tire replacement business. Ever my local COOP doesn't due on-farm tire service anymore.
If you have to replace all the tires on a tractor like an IHC M, with front and rears you could easily end up shelling-out $1300. Something to consider when buying a used tractor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
