Re: New Farmall 450
Posted by pete 23 on October 03, 2009 at 20:41:32 from (173.87.8.73):
In Reply to: New Farmall 450 posted by SCpuller1 on October 03, 2009 at 19:21:35:
Most likely a 450 won't have a seasonal disconnect but it may have. Most run the pto in the engaged position if they don't need it as the planetery gears are turing at a lower speed than when disengaged, however, I would make a shield with a closed end over shaft if I was to do that. Also, the pto rear unit is a self contained unit so fluid is seperate from rear end. Often times it never gets changed. TA, your call, use it as needed. Direct drive has least amount of moving parts.
