I'll just throw this in. Best way, preoiler, next best, crank without compression until oil pressure registers. Keep in mind though, the older engines use a bypass oil filtering system and as soon as pump gets hold of oil it will be sent directly to the gallery, but later engines with full flow filters need to fill that filter first so it takes them longer to pressurize oil gallery. Normally you won't have any problem just firing it up if you use a good assembly lube but that one time that you do is once too many.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
