Posted by IH fan on October 03, 2009 at 21:27:59 from (70.243.240.19):
In Reply to: Disc on Super M posted by TxFarmallFan on October 03, 2009 at 03:53:29:
Hugh MacKay said: (quoted from post at 19:40:19 10/03/09) Another factor, worn blades require far less hp. It will surprise you how many folks have never used anything but well worn blades, they don't do much but will pull easy.
I do know that one of the JD 10' discs was new and not JDs lightweight disc, it was their heavyweight flexable disc from 1953, whatever model that was. New 1953 JD 60, 3x14" plow and 10' disc. The later (after I was grown and gone from home) 460 and 11 1/2' Kewanee were both used and the disc diameters may have been worn, but were rolled and sharp. Maybe the NE Iowa ground works easier than where you live... I know it was not clay on top.
I used to take a weeks vacation in the summer to help a friend here in Kansas. He bought a new 25' Krause flex-wing with the narrow spacing and I pulled it with a 155 Hp JD 4640.... how does that add up in your part of the world? Would you have been pulling an 18' or 20' instead and maybe a 6x16" plow instead of that 8x16" plow he pulled (I never personally pulled that one but used his 970 Case and 5x16")?
This post was edited by IH fan at 21:46:26 10/03/09 2 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
