Re: H head lights not working
Posted by Janicholson on October 04, 2009 at 07:42:14 from (64.61.211.98):
In Reply to: H head lights not working posted by edenvt on October 04, 2009 at 06:33:48:
Check with a test light as follows:
Power at the load side of amp meter (side not connected to starter switch terminal)
power at light switch from Amp meter.
Power at wire going to lights (either in the D or B positions, with dimmer in the D position)
Power at the light bulb on each side of tractor.
Power at the ground of the bulb, If power at the ground, the ground is bad!! Voltage must be used at the bulb. JimN
