Re: 1486 needs more power
Posted by Larry B 1486 on October 04, 2009 at 07:42:15 from (67.142.161.31):
In Reply to: Re: 1486 needs more power posted by Hugh MacKay on October 03, 2009 at 17:45:45:
Hugh, I don't fool around. I make my living doing this. If you all look at balers made today, they are just like buying combines today. It all about how much you can get thru one per day. I can take an older baler and make the same size bale but probley take three times longer using a tractor under 100hp but todays balers are made for high hp tractors and pulling one if the ground is smooth enough up to 10 mph not 3mph. I have custom baled for 27 years and started with a 560 with a 505 vermeer baler and would be lucky if the old 560 would pull this baler up a hill the empty. We use a rake taking 27 ft and puttind winrows you can barely get under the tractor. Sure you can pull a baler with under 100hp, I did it for years with my 856 but not baling 30-40 bales and hour puttin that kind of volume and speed into one but the old balers would not handle how I bale today. I know
