Re: Ridge at bottom of sleeve
Posted by Janicholson on October 04, 2009 at 07:50:16 from (64.61.211.98):
In Reply to: Ridge at bottom of sleeve posted by Randy D McClenahan on October 03, 2009 at 19:25:36:
I agree with TractorSam.
The taper in the cylinder must be less than .005" total from below any ridge, to the highest wear point at just below the top ridge. If taper is any more than that, piston slap, and the continuous working of the rings (in and out of the ring grooves pumping oil) will seriously disappoint you. A sleeve kit including most of the needed parts can be had reasonably. This sight sells them.
Doing it twice is far more expensive. JimN
