Re: pre oiling new engine overhaul
Posted by Janicholson on October 04, 2009 at 08:03:12 from (64.61.211.98):
In Reply to: pre oiling new engine overhaul posted by Icuby on October 03, 2009 at 15:58:54:
El Toro is correct. If the pump has a tough time priming, it is a cheap insurance to prelube it. Even a pump oilcan and piece of hose into the oil pressure gauge fitting will work. Many Cubs will not prime unless packed on assembly with grease (split of tractor to get at the pump)or primed. JimN
