Re: Farmall MD HIGH oil pressure
Posted by pete 23 on October 04, 2009 at 19:56:04 from (173.87.8.73):
In Reply to: Farmall MD HIGH oil pressure posted by llamraf on October 04, 2009 at 19:10:23:
You indicate M diesel, the pressue regulator valve is in the oil filter base and pressure normally runs about 45 psi on the diesel engines. Haven't had base off have you and got gasket on wrong.
