Re: model m hood
Posted by glennster on October 04, 2009 at 20:13:22 from (24.14.63.246):
In Reply to: Re: model m hood posted by TAP on October 04, 2009 at 19:32:19:
you are prolly gonna need to loosen up the bottom radiator mountbolts, also there is a strut rod that goes from below the oil and temp gauge forward and bolts to a bracket on the radiator, with some wiggling and re-aligning, you should get a decent fit. someone prolly had the radiator off in the past and wasnt to concerned with lining everything up. tractor prolly has been majored a few times in it life. also check the serial number and see if it ends in X 1. that was the code for a gasoline tractor. if not, it was a distillate or kerosene tractorand did have the starting fuel tank originally.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
