Re: clutc drag on 1466
Posted by The tractor vet on October 04, 2009 at 22:36:53 from (75.19.126.160):
In Reply to: clutc drag on 1466 posted by Yellott Canby on October 04, 2009 at 18:21:44:
Well first drop the cover on the bottom of the bell housing and see what all falls out if ya find EXTRA PARTS that look mangled then more then likely the damper springs are broken on the disc and are jaming the pressure plate from releasing . That maybe one problem It also could be and EYE bolt on the release lever broke and only two fingers are working . Any of the above will requier a split and a new clutch and disc. If this is needed the also have the flywheel reground and the step cut to assure propper step hight to face of the flywheel . If the free travel is correct and nothing has changed there ya may try and adjust the transmission brake .
