Posted by D Slater on October 05, 2009 at 06:06:33 from (72.65.137.34):
In Reply to: Stuck Clutch Pedal posted by JeffnPA on October 04, 2009 at 20:11:51:
When you say pedal, I take it you have a industrial 6 with a foot clutch and the pedal stays down even when foot is removed. If you can't see a problem on the outside. Unless something unusal happened to make the pressure plate stick in the released position the fingers should push pedal back most of the way, enough for tractor to go. Would check the sleeve the release bearing carrier slides on, fork and carrier for breakage or other problem blocking pressure plate engagment. You may be able to see whats happening through the inspection hole on bottom. If not the top of clutch housing will need removed.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
