Re: Stuck Clutch Pedal
Posted by rustyfarmall on October 05, 2009 at 06:20:33 from (209.152.78.140):
In Reply to: Stuck Clutch Pedal posted by rustyfarmall on October 05, 2009 at 04:37:39:
rustyfarmall said: (quoted from post at 04:37:39 10/05/09)
There is a return spring located inside the clutch housing. It probably broke. You can replace it from under the tractor.
OOPs, there is no access to it from underneath. You need to remove the top cover.
