Re: Is the Farmall 45O a CAT 1 or 2
Posted by CNKS on October 05, 2009 at 08:41:57 from (216.144.104.128):
In Reply to: Is the Farmall 45O a CAT 1 or 2 posted by ssickel on October 05, 2009 at 08:27:05:
The spacing on the fast hitch arms on a 450 is about cat 1. For 3 point conversions, it can have adapters for cat 2 -- so it depends on how the owner had it set up. I believe the 3 point on the 530 was cat 1 only, not sure about that. Don't know how the splitter is set up, but if it is cat 2 and has removable lower pins, you can get cat one pins and put them on the inside of the brackets to make it fit your 9N.
