Farmall M Carb/Governor Question
Posted by chadd on October 05, 2009 at 19:46:36 from (4.142.198.70):
Since replacing the manifold on our M, it has had a problem with galloping/ surging under load. It reacts very abruptly under light load and refuses to hold rpm under heavy load. I noticed that the throttle plate slides back and forth on the throttle shaft. The screws are completely tight. Is this normal? The amount of slide is about 1/16" and with the throttle plate open is in the vertical direction.
Thanks.
