I had a chance to use the tractor today. It is a whole lot better than it was in that the forklift mast doesn't shift from side to side while underway. However, it will tilt if the load is uneven when changing the elevation with the cylinders. It will correct itself when the strokes are fully extended or retracted. I will just have to set the fast hitch where I want it and change the fork height with the forklift electrical power-pac. So in that regard, the lift is very functional now.
To correct the tractor hydraulics, I will have to install a flow control valve so that equal volumes go to each cylinder regardless of load position. Maybe next year or whenever I find a suitable valve.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
