Re: Farmall M idling
Posted by Bob M on October 06, 2009 at 12:57:02 from (151.190.254.108):
In Reply to: Farmall M idling posted by sven on October 06, 2009 at 12:47:28:
Sven - A few suggestions for things to check:
1 - Verify all valve clearances are set per the book.
2 - Check/fix any vacuum leak at both the carb to manifold and manifold to head gaskets. (Gaskets in good shape? All bolts tight?)
3 - Could it be you disturbed the idle air flow adjustment when you had the carb off? (Mess with this only after eliminating #1 and #2 above!)
