Re: 300u clutch
Posted by MHMalcolm on October 06, 2009 at 15:06:50 from (66.66.148.252):
In Reply to: 300u clutch posted by JSmith Farm on October 06, 2009 at 13:35:44:
You say the fingers pressed all the way in when you bolted the pressure plate to the flywheel. If I'm interpreting what you are saying correctly, it sounds as if your new clutch disc is too thick for your pressure plate. The distance from the friction face of the pressure plate to the release bearing contact surfaces on the release fingers needs to be adjusted to 2-7/32" after the pressure plate is bolted to the flywheel. If it is any less than that, the clutch won't release all the way or at all. If this dimension was correct, then you will need to adjust you clutch pedal free travel with external clutch pedal linkage. If your tractor has a torque amplifier, this adjustment is a little more involved. My email is open. Send me an email and I will email you a scan of the adjustment procedure.
