Re: clear fuel filter on a /farmall A
Posted by Andy Martin on October 06, 2009 at 15:19:18 from (199.197.2.141):
In Reply to: Re: clear fuel filter on a /farmall A posted by MHMalcolm on October 06, 2009 at 15:12:13:
I routinely put inline filters on my tractors (M's, H's, A's, C's) because the screen in the carburetor is gone. They get used a lot, and the clear ones never fill up.
Installing a copper line is not a good idea as the copper tends to work harden as it vibrates and will eventually crack and fail. This can result in a tractor fire. We always replace copper lines on tractors we buy to avoid failure. Rubber fuel lines seem to work OK but may lead to vapor lock depending on where the rubber is in relation to the exhaust manifold.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
