Re: Farmall H electrical questions
Posted by Andy Martin on October 06, 2009 at 15:29:46 from (199.197.2.141):
In Reply to: Farmall H electrical questions posted by farmerwannabe on October 06, 2009 at 14:22:34:
It was originally positive ground, but that does not mean someone has not changed it to negative ground. Likely however, someone took the old battery out and put a new one in without noticing it was positive ground. The starter works right either way. Even though it is a DC motor.
Search the site for a wiring diagram. The old regulator may be OK but likely needs replacing. John T has given excellent charging system trouble shooting instructions many times.
