Re: Farmall H electrical questions
Posted by farmerwannabe on October 06, 2009 at 15:50:19 from (4.154.131.179):
In Reply to: Re: Farmall H electrical questions posted by D Slater on October 06, 2009 at 15:00:40:
Thanks for the replies. Glad to know the regulator is in the right place. I will plan on replacing it when I get a new wiring harness. About the negative ground, I"ve heard that if I change the battery back around I would have to repolarize the generator somehow, and someone else said it was a good way to blow the battery up. What would I need to do to be able to have it positive ground again?
