Re: Troubleshooting problem with 2400A IH
Posted by jimb2 on October 06, 2009 at 16:30:08 from (99.240.236.11):
In Reply to: Troubleshooting problem with 2400A IH posted by Cabooze on October 06, 2009 at 13:40:51:
Hi believe 2400A is similar to 454. If this was a Diesel, I would tell you to check the fuel flow from the fuel tank. A common prolem with this model of tractor is junk in the fuel tank restricting flow out of the fuel tank. Usually have to drain tank and remove both shut off valves in bottom of fuel tank and clean tank and valves.
JimB
