Re: 1944 M overhall
Posted by HicksDale on October 06, 2009 at 17:30:11 from (74.36.247.188):
In Reply to: 1944 M overhall posted by oldiron29 on October 06, 2009 at 13:59:22:
Use an angle grinder to cut the sleeve vertically and then the piston will come out. May have to use a chisel to spread the sleeve to break the piston loose. I had used a torch and press and couldn't get the piston out, but was easy after cutting the sleeve. Good luck.
