Re: 6 volt genny or reg?
Posted by KEB1 on October 06, 2009 at 19:44:49 from (97.124.149.220):
In Reply to: 6 volt genny or reg? posted by jonnny2006 on October 06, 2009 at 16:43:22:
"at around 20 amps and goes down slow and once it hits zero it stops charging"
Sounds about right to me. Charge current decreases as the battery charges, and should reach zero when the battery is fully charged. The ammeter measures current into and out of the battery. When the lights are running on the generator, they aren't drawing current from the battery.
If you force current into the battery after its charged, you'll boil out the electrolyte and eventually destroy the battery.
Does the switch position affect the charge rate? If so, you have a cutout relay and not a regulator.
Keith
