Posted by soybeanjoe on October 06, 2009 at 19:59:57 from (66.213.171.108):
In Reply to: Re: 706 hyds posted by pete 23 on October 06, 2009 at 19:45:19:
<<<<< As far as remotes not releasing when engine is shut off, you must have check valve assembly on your tractor, were an option, and they require hyd pressure to release. >>>>>>>
I didn't realise there was such an option available for the 06 series tractors & I have been an IH man since the '50s. Quess you learn something every day. On this 706 the hyd remote outlets come out the side of a rectangular block unlike the remotes on our 806 & 1206 which come straight out from the control valves under the seat Would this be the check valve you are talking about?
I'll check the lift cylinder in the morning & see if it is extending all the way or if it can be raised by hand in the "full up position"
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
