Re: 300u clutch
Posted by Owen Aaland on October 07, 2009 at 03:29:31 from (207.13.114.55):
In Reply to: 300u clutch posted by paul maloney on October 06, 2009 at 13:35:44:
JSmith Farm said: (quoted from post at 16:35:44 10/06/09) I have replaced the clutch disc in my 300u but not the preassure plate. everything was in good condition when we took it apart so we only replaced the disc. When I put it back together and adjusted the pedal the clutch still wont work. the clutch fingers pressed all the way in when I bolted the plate to the flywheel and the bearing just touches them when the pedal is pressed all the way down. Im not real sure what to do next. Everything was assembeled acording to the book.
A new disk should require a pedal adjustment but it shouild not be extreme. When a clutch is assembles the lever (fingers) should be parallel with the flywheel surface or slightly closer. If all you changed was the disk and the was pressure plate assembly working Okay before you took it apart, most likely the disk is in backwards.
There should be no reason to adjust the lever height. Once you start to adjust the levers you are just masking other problems.
