Posted by Owen Aaland on October 07, 2009 at 03:35:40 from (207.13.114.55):
In Reply to: 300u clutch posted by Hugh MacKay on October 06, 2009 at 13:35:44:
Moondoggie said: (quoted from post at 22:51:35 10/06/09) Just read this post. I have a 340U. Curious about the finger adjustment. TA didn't work. I adjusted the engine and TA clutch linkage together, by the book. TA still won't engage at all. Looking through the top inspection cover, I can see no movement of the disc or pressure plate and the TA handle requires enormous pressure to pull back! Is this a finger adjustment problem? Does the fix involve a split I can look forward to this winter?
I think you need to reread the adjustment procedure again. It sounds as though you have the TA clutch release bearing adjusted so that the clutch is fully released before you start to move the lever. If you want additional help with the adjustment we can walk you through the steps to make sure the adjustments do what they are supposed to do even if the linkage is worn so that the normal procedure does not work.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
