Posted by 510 plows on October 07, 2009 at 07:39:32 from (134.29.140.199):
A friend of mine has a Farmall H that the clutch chatters when you are letting the pedal out slowly. We dropped the Hyd pump out and replaced the clutch with a new Reman unit, and it does the same thing. We replaced the disk, pressure plate and both bearings.
We have pulled the unit back apart and pulled the input shaft to the transmission out this time and inspected it. Where the yoke attaches to the front of the shaft we found that the bolt and washer were missing and had some play in the woodruft key, Had that repaired and put everything back together and the clutch still chatters when you first start the tractor moving.
I'm not sure where to go next. The clutch is good and solid when the pedal is all the way back, pulls good and does not slip. It just chatters when you first start moving. Thanks much for any help you can give me. charlie
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
