Re: M whats the year??
Posted by D Slater on October 07, 2009 at 10:01:52 from (72.65.137.34):
In Reply to: Re: M whats the year?? posted by F-Dean on October 07, 2009 at 08:49:05:
You misunderstood my answer. I didn't mean to imply the numbers were real close. Just that from the engine serial # depending on what it is that I could probably tell what month the engine was put in a tractor. From there I could at least tell what serial range and month the tractor was built. If engine serial # is higher than the number I posted I can tell what tractor serial # it came in 95% of the time. It also depends if the chassis and engine are original to each other. Date codes should be checked to get a idea on that. Late carburetor M tractors can have 13000 or more spread between engine and chassis. Older less or none.
