Re: 6 volt or 12 volt Gen
Posted by Bob M on October 07, 2009 at 12:30:41 from (151.190.254.108):
In Reply to: Re: 6 volt or 12 volt Gen posted by kevin baird on October 07, 2009 at 09:48:28:
The presence of a ballast resistor says someone converted your SM to 12 volts.
The 3 terminal regulator also suggests 12 volts. You might get lucky and find the regulator marked on the underside with voltage and polarity.
Keep in mind the original SM 6 volt regulator had 4 terminals. But 3 terminal, 6 volt regulators exist and when properly wired up will work on a Super M.
You might try to get a part number off the generator nameplate then try to locate the matching regulator.
