Re: 6 Volt Generator Armature for 1959 Farmall 140
Posted by El Toro on October 07, 2009 at 12:44:27 from (74.103.74.58):
In Reply to: 6 Volt Generator Armature for 1959 Farmall 140 posted by KED on October 07, 2009 at 10:14:07:
You can call this repair shop to see if they have an armature. You will probably need the model number of the generator. Hal
1-800-858--8517 or 410-879-9510
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
