Re: Won't Start
Posted by El Toro on October 07, 2009 at 17:09:08 from (74.103.74.58):
In Reply to: Won't Start posted by TOM TOMSKY on October 07, 2009 at 13:09:51:
Pull a plug wire off and see if you have fire while a helper tries to start the engine with the ignition switch on. If there's no fire and you have a distributor you need to check for battery voltage at the coil with the points open
and the ignition switch on. Should have battery voltage on both small terminals.
If you have fire to your plugs you probably have fuel blockage between the tank & carburetor. Pull the gas line at the Carburetor and see if you have a full stream of gas. If that looks ok
remove the tube fitting your gas line connects to and remove the screen. It may blocked. Hold your hand over the throat of the carburetor and have someone make an attempt to start the engine.
Make sure the switch is on. You need good suction to get that atomized fuel into the engine. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
