Re: 300u clutch
Posted by MHMalcolm on October 07, 2009 at 17:12:32 from (66.66.148.252):
In Reply to: Re: 300u clutch posted by Josh Smith on October 06, 2009 at 16:32:49:
I think the guys above are right about the disc being in backwards doing this too. If you don"t know for sure it is in right, that is the first thing you should check. The long side of the splined hub on the disk has to face rearward. I do disagree about the statements that you should not adjust the fingers. They need to be set to the proper height to compensate for the wear on the pressure plate, and also the flywheel if you didn"t have the flywheel resurfaced. Plus, you need to make sure the fingers are all at the same height, or the the clutch may release and engage unevenly, which could lead to premature clutch wear and failure. I don"t want to offend anyone- it is just what I believe.
