Re: 606 TA questions
Posted by Owen Aaland on October 07, 2009 at 17:52:29 from (207.13.114.55):
In Reply to: 606 TA questions posted by Loren in MN on October 07, 2009 at 05:26:03:
CNKS said: (quoted from post at 20:35:51 10/07/09) You got me shortly after my brain died--what I should have said, which really doesn't apply to the question, is that you don't have to do the 2nd split to remove the TA to remove the disk, I didn't bother the pressure plate.
I was pretty sure you were just referring to the second split. Even so it can be a lot of fun on some models to get the top plate off to access the TA clutch. Once you do get the cover plate off the TA pressure plate, disk, and flywheel can all be removed.
