Re: lift capacity
Posted by CNKS on October 07, 2009 at 18:43:18 from (216.144.104.128):
In Reply to: lift capacity posted by Harry Huggins on October 07, 2009 at 18:28:15:
In a word, no. In more words, I used to spray with a International 444, had 3-55 gallon tanks, or about 65% more than yours on a heavier tractor with weight on the front end. The front floated, the hydraulics did not like it. I could get by ok with two of the tanks, or perhaps 40 gal in each (120 gal) at the most, but it was still light. I doubt if the hyd will raise it, but your main problem is weight. You might get by with 50 gallons. That's about 350 lbs of water. You might consider spraying at 10-15 GPA, to get more acres out of a tank. My current 55 gal sprayer uses 13 GPA at 5 mph, which is fast enough.
