As CNKS says, there is not supposed to be oil in the axle carrier (the cast piece that contains the axle). The outer bearing is only lubed by the grease fitting unless oil is leaking past the inner seal which is at the transmission end of the axle. Replacing that inner oil seal is a pretty big job, so if the leak is not too bad, you might just want to live with it or possibly do only the outer seal which only requires removing the wheel from the axle. However, It's likely replacing the outer seal will only slow down the leak not get rid of it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
