Re: Sealing Farmall 504 oil filter housing gasket
Posted by Owen Aaland on October 07, 2009 at 22:33:02 from (207.13.114.55):
In Reply to: Sealing Farmall 504 oil filter housing gasket posted by cfitch on October 07, 2009 at 21:44:18:
I assume that you are referring to the gasket between the filter canister and the block. If that seal ring type gasket is the one that is blowing out, you still have an old gasket stuck in the block. Most likely it is so hard you will have to chisel it out. The new gasket should fit down inn the groove, not stick up above the casting surface.
