Re: Low oil pressure in a C
Posted by P and R Pete on October 08, 2009 at 05:53:27 from (173.86.56.237):
In Reply to: Low oil pressure in a C posted by Pete in Holland, MI on October 08, 2009 at 04:44:17:
I don"t have a C, I have a Super-A, but on my oil pump, part of the gasket between the pump and it"s cover was blown out.
I can"t tell you if that was the sole source of low pressure for me, because I overhauled the engine at the same time, but it couldn"t have helped.
Hopefully your C is the same: my oil pump removal was as easy as dropping the pan, and removing two bolts on the right side of the engine, and the oil pump (with a little wriggling) dropped right out.
Mine has a "floating" sump with a screen, and it"s worth making sure your screen isn"t gummed-up with sludge, which would also reduce flow. It"s an easy start to tracking down the problem!
