Re: Low oil pressure in a C
Posted by glennster on October 08, 2009 at 06:02:56 from (99.139.125.51):
In Reply to: Low oil pressure in a C posted by Pete in Holland, MI on October 08, 2009 at 04:44:17:
also, when you drop the oil pump cover, look for wear marks from the pump gears. real common problem. my b was worn and also the super m i am currently rebuilding. you can take some emery cloth on a sheet of glass, and using a figure 8 pattern, sand the surface back smooth
