Posted by Melvin Ware on October 08, 2009 at 07:23:19 from (4.152.108.232):
Thanks to all who talked me through the belt replacement on my Farmall M. Loosening that split pulley proved to be quite an ordeal and I couldn’t have done it without your help.
Also learned a few other tricks along the way;
1. An impact screwdriver is a good tool for breaking loose a stubborn setscrew. (I've since replaced the slotted screw with a square head screw.)
2. After weeks of soaking in PB and tapping with an oak dowel the pulley wouldn't budge so tried operating the tractor with setscrew removed while monitoring the pulley at frequent intervals. After about an hour of heat and vibration it finally broke free on its own.
3. Since I couldn't find a "brass drift" I was using my oak dowel to try and open the pulley further which didn't work very well. Upgraded to a 3/8" mild steel rod from Lowes which did a better job. After about an hour of tapping on the hub, the rod ends had "mushroomed" but no apparent damage to the hub and the belts were off!
4. In hindsight, applying some paint remover to clean paint from the threaded hub probably would have made the job much easier.
5. In the final stage of tightening the belt I found that a quick jerk (ccw) on a fan blade seemed to work better than tapping on the hub.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
