Posted by chadd on October 08, 2009 at 10:38:46 from (70.239.120.177):
Ever since our Farmall M generator was rebuilt, it has required higher engine rpm before it would begin charging. Prior to rebuild, it would charge as long as engine rpm remained about 1/8 throttle or so, even with the lights on. Now anytime the throttle is below 1/4-1/2 open, it will drain (severity depending on electrical load). Also, at full throttle, the needle on the ammeter will bounce back and forth between charge and drain with occasional periods where it will settle down at a slight charge. The VR has been replaced, and it still does it. A multimeter shows that the generator charging rate does seemingly randomly bounce around, and not stay at a set value. Does this sound like a ground issue? My continuity tester says about 7 ohms between chassis ground and ammeter, generator to chassis ground, and VR to chassis ground. The battery never goes dead, but I find such large current swings between +-30 amps a little concerning. It goes away below 7/8 throttle or so and shows a slight charge of a few amps.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
