Re: Identifying A Loader
Posted by Hugh MacKay on October 09, 2009 at 00:21:08 from (216.208.58.187):
In Reply to: Identifying A Loader posted by John G. Hasler on October 08, 2009 at 19:57:15:
John: If it is a pipe frame loader, (very unlikely as they were 400-450 vintage) two possible choices 33 or 33A.
Next came the 1701 and 2001 both used on 460-560 tractors, and the last loaders to have sub frame go back to rear axle carriers. 2001 is quite a bit heavier, most likely the one chosen for 560. Sub frame is exactly same as 2000, only real difference in the two loaders is end of lift boom. 2001 has one dump cylinder in center, 2000 has two dump cylinders, one on each lift arm.
