Re: Farmall ?
Posted by tackhammertime on October 09, 2009 at 08:49:03 from (72.155.5.143):
In Reply to: Farmall ? posted by jayinNY on October 09, 2009 at 07:46:02:
If you are talking about the lever in the manifold it was for running on karosene. kept the tractor hotter so it would burn better. The manifold should look like the one in the picture. If your running on gas you keep it open. Mine on this H is frozen up open.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
