Re: Plow
Posted by Janicholson on October 09, 2009 at 14:46:11 from (64.61.211.175):
In Reply to: Plow posted by djone110 on October 09, 2009 at 14:21:00:
2-14 is correct for that tractor. Two moldboards, with each turning 14" of earth. Measure between the main frame members perpendicular to them to determine the 14" width.
I like the type that has a fixed tail wheel in the furrow. They seem to track straighter. JimN
  • Re: Plow RAW in IA 17:38:52 10/09/09 (0)
  • Re: Plow JayinNY 15:00:47 10/09/09 (1)
    • Re: Plow djone110 15:05:46 10/09/09 (0)
  • Re: Plow djone110 14:52:05 10/09/09 (1)
    • Re: Plow davejoe 19:40:25 10/09/09 (0)
