Re: JB Weld question(s)
Posted by HENRY E NC on October 10, 2009 at 06:13:25 from (67.142.163.30):
In Reply to: Re: JB Weld question(s) posted by pgo12 on October 10, 2009 at 00:31:35:
JB Weld is ok for all that stuff. PC 7 is better for glueing. PC makes a whole line of epoxy type fillers and is a great adhesive. Found at Ace Hardware stores. Clean well with alcohol or lacquer thinner before applying. Keep a fairly even mix. Too much hardner will make it crumbly . Henry
