Re: E4A mag
Posted by Hand Culcth on October 10, 2009 at 06:18:33 from (98.224.115.127):
In Reply to: E4A mag posted by Tony S. on October 09, 2009 at 20:51:38:
Always mark it before you remove it. If you take a good look at it, you can probably tell wich side was toward the engine block. If not restall with hoter spark. Use a pice of paper. Put it btween the spark plug wire and a ground. Trip the mag. Wich ever way the magnet is that burns a bigger hole in the paper is the correct way for the magnet.
