Re: 1066 steering repairs questions
Posted by Brownie 450 on October 10, 2009 at 11:32:06 from (66.43.241.141):
In Reply to: 1066 steering repairs questions posted by Michael Sheik on October 10, 2009 at 10:41:44:
Center 1 inch pin that holds the wishbone [one in the front axle casting] is held in with a roll pin. Drive roll pin out & pin should fall out. When putting this pin back, have an assortment of 1 inch washers on hand to shim up the empty space between wishbone & axle casting. Get as little slack as you can in this area.
The bushings are straight forward--use a hacksaw to cut through the 1 inch bushings [remove blade from saw & insert it through the bushings & then reassemble blade on hacksaw].
On the large steering cylinder bushings, use a small chisel to cut through them. Could probably use a die grinder also.
