Posted by tackhammertime on October 10, 2009 at 17:49:03 from (72.155.5.143):
I had to replace a front tire today and when the old tire & tube was taken off the rim a chunk of the rim around the valve stem came with it. I brought the rim back to the shop ground out the rot then started to weld a new piece of steel into place. When the welded area started turning colors I remembered the rims were galvanized. I took it out into the fresh air, put on a respirator, and finished welding. Then drilled a new valve stem hole. On my old H the front rims cracked around the tabs and I took them and had them welded. Do these old rims have enough galanize to hurt a person? Just wandering.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
