Posted by KenB_Texas on October 10, 2009 at 18:28:53 from (216.82.216.252):
I thought this was straight forward and I could figure it out but I think I may need some help. I bought a non running H and the shift lever was not installed correctly and is loose. I lined up the rails, installed the shifter and installed the pin but it does not work right. The pin is loose and the shifter comes out of the rails when you try to move it. (IF you are not careful you will pinch your fingers when the shifter hits the post) I was thinking I had a wrong shifter and tried getting one off of a parts tractor but I could not get the pin to move. I bent my pin punch hitting on it. The parts diagram shows 2 different pins (small and Large) as well as a "Gear Shifter Lever Swivel Shaft Hole Plug" I am confused, what am I missing here?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
