Posted by Janicholson on October 10, 2009 at 19:40:04 from (64.61.211.61):
In Reply to: Suepr C Quit posted by Retcol on October 10, 2009 at 15:53:21:
Take a spare plug (any with the correct wire tip on it) and see if has fire. Pull one wire off of a plug and put the spare in the wire. ground the wire and crank it. If no spark, see if there is voltage at the coil from the ignition button. If not the button or a wire is bad. If it has volts there, clean the points and set to .020" on a distributor cam lobe. If it has a mag, make sure the wire going to the mag is not grounded (removing it works) then see if there is spark. Mags do not get power from the electrical system. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
